メインコンテンツにスキップ
Canon PowerShot SX600 HS Flash Assembly Replacement
Scott Childress
Scott Childress とその他 人の作成者
最終更新日: May 15, 2017
10 - 15 分
中レベル
By fixing your flash, you can once again take bright, vibrant photographs.
必要な工具と部品
ツール
もっと見る
  1. Canon PowerShot SX600 HS Flash Assembly Replacement, Battery: 手順 1、 1の画像 1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 2、 1の画像 1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 3、 2の画像 1 Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 3、 2の画像 2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Flash Assembly Replacement, Power and Shutter Buttons: 手順 4、 1の画像 1
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 5、 1の画像 1
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 7、 2の画像 1 Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 7、 2の画像 2
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 8、 1の画像 1
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
  9. Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: 手順 9、 2の画像 1 Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: 手順 9、 2の画像 2
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
  10. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 10、 1の画像 1
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
  11. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 11、 1の画像 1
    この手順で使用する道具:
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
  12. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 12、 1の画像 1
    • Gently lift the protector from the frame.
  13. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 13、 1の画像 1
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
  14. Canon PowerShot SX600 HS Flash Assembly Replacement, Flash Assembly: 手順 14、 1の画像 1
    • Unplug the assembly from the main no-fuss connector.
  15. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 15、 1の画像 1
    • Unplug the assembly from its flat-top connection.
  16. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 16、 1の画像 1
    • Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
  17. Canon PowerShot SX600 HS Flash Assembly Replacement: 手順 17、 1の画像 1
    • Gently lift the assembly out of its place.
終わりに
Fix your Canon's flash in order to take bright, vibrant photographs.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Scott Childress
メンバー登録日: 02/15/17
752 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S6-G4, Lacy Spring 2017 USF Tampa, Team S6-G4, Lacy Spring 2017人のメンバー
USFT-LACY-S17S6G4
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 1,030
