はじめに
First remove the back casing and control dial before attempting to remove buttons.
パーツ
パーツは指定されていません。
Turn the camera to the side that the screen is showing.
Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
Turn the camera with the lens facing down.
Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
Carefully put pressure on the opening tool so the cover can gradually open.
Slowly slide the opening tool along the gap and around the edge of the camera.
Once you have removed the back cover this is what the camera will look like.
Locate the Control Dial.
Once casing and control dial have been removed, you will begin removing silicone button pad.
Use tweezers to grip the edge of the silicone pad and begin lifting upward.
