メインコンテンツにスキップ
Canon PowerShot S410 Back Cover Replacement
Randy Lormand
Randy Lormand とその他 8 人の作成者
最終更新日: July 2, 2024
4 - 5 分
簡単
This guide demonstrates how to remove the back cover of your Canon PowerShot S410 for cleaning or replacement. You will also need this guide to access the internal components of your camera for other repairs.
必要な工具と部品
ツール
  1. Canon PowerShot S410 Back Cover Replacement, Battery: 手順 1、 2の画像 1 Canon PowerShot S410 Back Cover Replacement, Battery: 手順 1、 2の画像 2
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 Back Cover Replacement: 手順 2、 1の画像 1
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 Back Cover Replacement: 手順 3、 2の画像 1 Canon PowerShot S410 Back Cover Replacement: 手順 3、 2の画像 2
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
  4. Canon PowerShot S410 Back Cover Replacement, Back Cover: 手順 4、 1の画像 1
    • Start by laying the camera flat with the LCD screen facing up.
    • Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
  5. Canon PowerShot S410 Back Cover Replacement: 手順 5、 1の画像 1
    • Position the camera with the bottom facing up.
    • Twist the screwdriver counter-clockwise to remove the 4.8mm screw.
    • Repeat to remove the two 2.3mm screws.
  6. Canon PowerShot S410 Back Cover Replacement: 手順 6、 2の画像 1 Canon PowerShot S410 Back Cover Replacement: 手順 6、 2の画像 2
    • Position the camera so that the rubber "AV Out Digital" tab is facing upward.
    • Slide the rubber tab to reveal the bottom screw.
    • Using the screwdriver, remove the two 3.7mm screws.
  7. Canon PowerShot S410 Back Cover Replacement: 手順 7、 1の画像 1
    • Turn the camera with the back side facing you.
    • Grip the edges of the back plate, and carefully slide it off.
    • If there is any resistance in movement, double check there are no screws left in the chassis.
終わりに
作成者
8人の作成者と共同で作成されました。
Randy Lormand
メンバー登録日: 01/23/11
349 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 11-27, Maness Winter 2011 Cal Poly, Team 11-27, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G27
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,140
