メインコンテンツにスキップ
Canon PowerShot G1 X Buttons Replacement
Benjamin Irvin Bunch
Benjamin Irvin Bunch とその他 2 人の作成者
最終更新日: June 30, 2020
5分
簡単
アクションショット
Be careful when removing each screw on this camera. Each screw has a specific location and they are different sizes. The best way to make sure that you do not lose or misplace any screws is by making a list of what screws you take out and where it was located.
必要な工具と部品
ツール
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
  1. Canon PowerShot G1 X Buttons Replacement, Back Camera Casing: 手順 1、 2の画像 1 Canon PowerShot G1 X Buttons Replacement, Back Camera Casing: 手順 1、 2の画像 2
    • To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
    • Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
  2. Canon PowerShot G1 X Buttons Replacement: 手順 2、 1の画像 1
    • After removing the first screw flip to the bottom side of the camera and unscrew the two screws located toward the back side of the casing. The screw on the front side can be left in. Use a Phillips Head 00 screwdriver for both of these screws.
  3. Canon PowerShot G1 X Buttons Replacement: 手順 3、 1の画像 1
    • Now flip to the opposite side of the USB panel screw and unscrew the two screws holding the small speaker cover portion of the camera. Use a Phillips Head 00 screwdriver for both of these screws.
  4. Canon PowerShot G1 X Buttons Replacement: 手順 4、 1の画像 1
    • The last screw is located towards the top side of the back of the camera next to the view finder. Unscrew by using a Phillips Head 00 screwdriver.
  5. Canon PowerShot G1 X Buttons Replacement: 手順 5、 1の画像 1
    • Remove the side panel covering the speaker by gently pulling it away from the camera. You can also use spudgers to create a lever to help remove the panel.
  6. Canon PowerShot G1 X Buttons Replacement: 手順 6、 1の画像 1
    • Remove the back casing by gently pulling. You could also use spudger to create a lever to help pry it off.
  7. Canon PowerShot G1 X Buttons Replacement, Buttons: 手順 7、 2の画像 1 Canon PowerShot G1 X Buttons Replacement, Buttons: 手順 7、 2の画像 2
    • Remove the two screws above the buttons followed by the screw on the bottom, using a Phillips #00 screwdriver.
  8. Canon PowerShot G1 X Buttons Replacement: 手順 8、 1の画像 1
    • Remove the screw on the side of the buttons using a Phillips #00 screwdriver.
  9. Canon PowerShot G1 X Buttons Replacement: 手順 9、 1の画像 1
    • Gently remove buttons by hand, once all of the screws holding the buttons in are removed.
終わりに
作成者
2人の作成者と共同で作成されました。
メンバー登録日: 02/20/20
103 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 414
