メインコンテンツにスキップ
Canon PowerShot G1 X Back Camera Casing Replacement
Joseph Cosgrove
Joseph Cosgrove とその他 4 人の作成者
最終更新日: March 24, 2020
3分
簡単
アクションショット
To reassemble the device follow these steps in reverse order.
必要な工具と部品
ツール
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
  1. Canon PowerShot G1 X Back Camera Casing Replacement, Battery: 手順 1、 1の画像 1
    • Pull the switch on the back of the battery case back towards the open arrow to release a latch.
    • The lid should pop open revealing the battery and a small red switch holding the battery in place.
  2. Canon PowerShot G1 X Back Camera Casing Replacement: 手順 2、 2の画像 1 Canon PowerShot G1 X Back Camera Casing Replacement: 手順 2、 2の画像 2
    • To release the battery, gently push the switch off the top of the battery and pull the battery out of the casing.
    • Place the new battery in the casing with the four metal connections (small squares on the bottom of the battery)in the bottom right hand corner of the bottom of the camera. If you look inside the casing you will see where the connections will meet. This will give you more of an idea on the orientation of the battery.
  3. Canon PowerShot G1 X Back Camera Casing Replacement, Back Camera Casing: 手順 3、 2の画像 1 Canon PowerShot G1 X Back Camera Casing Replacement, Back Camera Casing: 手順 3、 2の画像 2
    • To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
    • Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
  4. Canon PowerShot G1 X Back Camera Casing Replacement: 手順 4、 1の画像 1
    • After removing the first screw flip to the bottom side of the camera and unscrew the two screws located toward the back side of the casing. The screw on the front side can be left in. Use a Phillips Head 00 screwdriver for both of these screws.
  5. Canon PowerShot G1 X Back Camera Casing Replacement: 手順 5、 1の画像 1
    • Now flip to the opposite side of the USB panel screw and unscrew the two screws holding the small speaker cover portion of the camera. Use a Phillips Head 00 screwdriver for both of these screws.
  6. Canon PowerShot G1 X Back Camera Casing Replacement: 手順 6、 1の画像 1
    • The last screw is located towards the top side of the back of the camera next to the view finder. Unscrew by using a Phillips Head 00 screwdriver.
  7. Canon PowerShot G1 X Back Camera Casing Replacement: 手順 7、 1の画像 1
    • Remove the side panel covering the speaker by gently pulling it away from the camera. You can also use spudgers to create a lever to help remove the panel.
  8. Canon PowerShot G1 X Back Camera Casing Replacement: 手順 8、 1の画像 1
    • Remove the back casing by gently pulling. You could also use spudger to create a lever to help pry it off.
終わりに
作成者
4人の作成者と共同で作成されました。
Joseph Cosgrove
メンバー登録日: 02/12/17
313 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 20-1, Remmell Spring 2017 USF Tampa, Team 20-1, Remmell Spring 2017人のメンバー
USFT-REMMELL-S17S20G1
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 9
今までの合計 715
