Canon PowerShot A2200 Button Assembly Replacement
はじめに
手順 1 に進むThis guide requires that you use a Phillips head screwdriver to remove the screws holding the buttons in place.
First, remove the batteries and memory card.
Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
Begin taking off the back cover with a plastic opening tool.
Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
Continue taking off the back cover along the left side of the camera as seen in the third picture.
ある他の人がこのガイドを完成しました。
