Canon EOS 20D Rear Case Replacement
必要な工具と部品
ツール
Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
Remove the two screws hidden under the viewfinder eyepiece cap.
Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
Once removed, a hidden screw is revealed.
Remove both screws from the rear of the camera.
Flip the lock on the flex cable connector up with a spudger.
The front panel should pop off, now that the cable has been disconnected.
4 の人々がこのガイドを完成させました。
