メインコンテンツにスキップ
Canon ELPH Z3 Camera Film Chamber Replacement
Nathan Barros
Nathan Barros とその他 2 人の作成者
最終更新日: February 19, 2020
5 - 10 分
中レベル
Film is a crucial component when it comes to cameras. It is necessary to replace the camera's film on a regular basis depending on the usage of the camera. This guide shows the quick and easy steps to show how to properly replace film in your Canon ELPH Z3.
必要な工具と部品
ツール
  1. Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: 手順 1、 3の画像 1 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: 手順 1、 3の画像 2 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: 手順 1、 3の画像 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Film Chamber Replacement: 手順 2、 3の画像 1 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 2、 3の画像 2 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 2、 3の画像 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Film Chamber Replacement: 手順 3、 2の画像 1 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 3、 2の画像 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Film Chamber Replacement: 手順 4、 3の画像 1 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 4、 3の画像 2 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 4、 3の画像 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Film Chamber Replacement, Film: 手順 5、 2の画像 1 Canon ELPH Z3 Camera Film Chamber Replacement, Film: 手順 5、 2の画像 2
    • Separate the front and back coverings of the camera completely.
    • Remove both coverings from the body of the camera.
    • Flip the camera upside down and focus on the bottom right portion.
  6. Canon ELPH Z3 Camera Film Chamber Replacement: 手順 6、 3の画像 1 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 6、 3の画像 2 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 6、 3の画像 3
    • Unscrew the 4.1mm screw using a PH000 screwdriver.
    • Swivel the now loose metal portion to the right.
    • This action will open the film chamber and thus exposing the film.
  7. Canon ELPH Z3 Camera Film Chamber Replacement: 手順 7、 3の画像 1 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 7、 3の画像 2 Canon ELPH Z3 Camera Film Chamber Replacement: 手順 7、 3の画像 3
    • Press gently on the film using your finger to slightly eject the film.
    • Pull the film from the chamber.
終わりに
作成者
2人の作成者と共同で作成されました。
Nathan Barros
メンバー登録日: 10/18/16
1 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S1G7
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 15
今までの合計 1,016
