メインコンテンツにスキップ
Bose Solo 5 Sound Bar Speaker Replacement
Chase Cooper
Chase Cooper とその他 3 人の作成者
最終更新日: September 15, 2020
15 - 20 分
簡単
If your Bose Solo 5 Sound Bar speaker is damaged or malfunctioning, this guide will walk you through how to replace the speaker so that the sound bar is properly functioning again.
The speakers in the Bose Solo 5 Sound Bar are responsible for producing quality audio. If a speaker is damaged, the audio coming from the sound bar might be distorted or impaired.
Before using the following guide, make sure that there isn’t any buildup of dirt, dust, or other debris that could possibly be inhibiting the audio. If this is the case, an ESD-safe brush or small dust blower usually can be used to remove the debris.
Prior to starting the guide, make sure to power off the device and remove it from connection to any sources of electricity.
必要な工具と部品
ツール
  1. Bose Solo 5 Sound Bar Speaker Replacement, Speaker: 手順 1、 1の画像 1
    • Lay Bose Solo 5 on its top side with the speakers facing away from you.
  2. Bose Solo 5 Sound Bar Speaker Replacement: 手順 2、 2の画像 1 Bose Solo 5 Sound Bar Speaker Replacement: 手順 2、 2の画像 2
    • Remove the two screws located at the outer edge of the backside with a Phillips head screwdriver.
  3. Bose Solo 5 Sound Bar Speaker Replacement: 手順 3、 1の画像 1
    • Lay the speaker on its backside with the speakers facing up. Wedge the plastic opening tool into the crack where the protective wire screen meets the housing. Pry apart until you create enough room for your fingers.
  4. Bose Solo 5 Sound Bar Speaker Replacement: 手順 4、 2の画像 1 Bose Solo 5 Sound Bar Speaker Replacement: 手順 4、 2の画像 2
    • Pull the screen gently away from the housing to reveal the two speakers with your fingers.
  5. Bose Solo 5 Sound Bar Speaker Replacement: 手順 5、 3の画像 1 Bose Solo 5 Sound Bar Speaker Replacement: 手順 5、 3の画像 2 Bose Solo 5 Sound Bar Speaker Replacement: 手順 5、 3の画像 3
    • Remove the 4 screws in each corner of the speaker to remove it from the housing.
  6. Bose Solo 5 Sound Bar Speaker Replacement: 手順 6、 2の画像 1 Bose Solo 5 Sound Bar Speaker Replacement: 手順 6、 2の画像 2
    • Peel back the styrofoam on the speaker & disconnect the yellow & brown wires by sliding them off the receptor.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Chase Cooper
メンバー登録日: 10/09/18
226 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team S15-G7, Blackburne Fall 2018 Sam Houston State, Team S15-G7, Blackburne Fall 2018人のメンバー
SHSU-BLACKBURNE-F18S15G7
2 メンバー
5のガイドは作成済み
コメント 1 件
Well opening the case affect its original sound tuning or will it affect the performance ?
Saket Adhau - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 31
過去 30 日: 137
今までの合計 14,221
