メインコンテンツにスキップ
Battery Removal
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Battery Removal, Display Opening: 手順 1、 2の画像 1 Battery Removal, Display Opening: 手順 1、 2の画像 2
  2. Battery Removal, Safety Requirements: 手順 2、 3の画像 1 Battery Removal, Safety Requirements: 手順 2、 3の画像 2 Battery Removal, Safety Requirements: 手順 2、 3の画像 3
    この手順で使用する道具:
    Safety Glasses
    $3.19
    購入する
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  3. Battery Removal: 手順 3、 1の画像 1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
  4. Battery Removal: 手順 4、 3の画像 1 Battery Removal: 手順 4、 3の画像 2 Battery Removal: 手順 4、 3の画像 3
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the Force Touch sensor.
  5. Battery Removal: 手順 5、 2の画像 1 Battery Removal: 手順 5、 2の画像 2
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Battery Removal: 手順 6、 3の画像 1 Battery Removal: 手順 6、 3の画像 2 Battery Removal: 手順 6、 3の画像 3
    • It's likely that the Force Touch sensor will stick to the display frame instead to the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
  7. Battery Removal: 手順 7、 3の画像 1 Battery Removal: 手順 7、 3の画像 2 Battery Removal: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • To avoid straining the display cables, don't open the display all the way yet.
    • Open the display at max. to an 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
    • Thread the adhesive around and behind the display cables to get it off completely. Since the adhesive needs to be replaced anyway, you can cut it if that makes removal easier for you.
    • Make sure to return to this point during the reassembly of your watch and then continue with the Resealing Procedure.
  8. Battery Removal, Battery: 手順 8、 2の画像 1 Battery Removal, Battery: 手順 8、 2の画像 2
    • Carefully fold the screen to the back until you get enough space to pry out the battery.
    • Avoid tensioning the display cables when folding the screen to the back.
    • Insert an opening pick between the battery and the Taptic Engine.
    • A regular opening pick works fine with the 44mm version of the Apple Watch Series 4. However if you own the 40mm version and don't have enough space you can customize your opening pick with scissors.
  9. Battery Removal: 手順 9、 3の画像 1 Battery Removal: 手順 9、 3の画像 2 Battery Removal: 手順 9、 3の画像 3
    • Slide the opening pick along the edge of the battery to loosen the adhesive.
    • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
    • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
    • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
    • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
    • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
  10. Battery Removal: 手順 10、 2の画像 1 Battery Removal: 手順 10、 2の画像 2
    この手順で使用する道具:
    購入する
    • Carefully lift the battery and bring it in a 75° angle.
    • Use a pair of tweezers to peel the black sticker off the metal plate which covers the battery connector.
  11. Battery Removal: 手順 11、 1の画像 1
    • Remove the Y000 screw (1.2 mm length).
  12. Battery Removal: 手順 12、 2の画像 1 Battery Removal: 手順 12、 2の画像 2
    • Use a pair of tweezers to remove the metal plate which covers the battery connector.
  13. Battery Removal: 手順 13、 2の画像 1 Battery Removal: 手順 13、 2の画像 2
    • Use the pointed end of a spudger to pry up and disconnect the battery flex cable.
  14. Battery Removal: 手順 14、 2の画像 1 Battery Removal: 手順 14、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    購入する
    • Remove the battery.
    • Be sure to remove the protective liner to expose the adhesive on your new battery before you set it in place.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
終わりに
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
作成者
4人の作成者と共同で作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
205,247 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,432のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 207
