メインコンテンツにスキップ
BLU Life XL Screen Replacement
Nathaniel Ennis
Nathaniel Ennis とその他 3 人の作成者
最終更新日: May 9, 2019
30分 - 1時間
難しい
間違いの指摘
One of the most common problems that smartphone users experience is a cracked screen. This guide will describe how to remove the screen of the BLU Life XL phone from the rear housing. Since the screen is very brittle, make sure that the front surface of the screen is taped with clear scotch tape to keep breaking to a minimum.
必要な工具と部品
パーツ
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. BLU Life XL Screen Replacement, Volume Control Buttons: 手順 1、 3の画像 1 BLU Life XL Screen Replacement, Volume Control Buttons: 手順 1、 3の画像 2 BLU Life XL Screen Replacement, Volume Control Buttons: 手順 1、 3の画像 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Screen Replacement: 手順 2、 2の画像 1 BLU Life XL Screen Replacement: 手順 2、 2の画像 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Screen Replacement: 手順 3、 2の画像 1 BLU Life XL Screen Replacement: 手順 3、 2の画像 2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Screen Replacement: 手順 4、 3の画像 1 BLU Life XL Screen Replacement: 手順 4、 3の画像 2 BLU Life XL Screen Replacement: 手順 4、 3の画像 3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
  5. BLU Life XL Screen Replacement, Motherboard: 手順 5、 2の画像 1 BLU Life XL Screen Replacement, Motherboard: 手順 5、 2の画像 2
    • Remove the two 12x3mm screws using the Phillips #000 screwdriver.
    • Remove the ribbon cables.
  6. BLU Life XL Screen Replacement: 手順 6、 3の画像 1 BLU Life XL Screen Replacement: 手順 6、 3の画像 2 BLU Life XL Screen Replacement: 手順 6、 3の画像 3
    • The ribbon cables are attached by zero insertion force (ZIF) connectors. To disconnect the cable, flip up the small locking flap and pull the cable out.
  7. BLU Life XL Screen Replacement: 手順 7、 3の画像 1 BLU Life XL Screen Replacement: 手順 7、 3の画像 2 BLU Life XL Screen Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Remove the white ZIF connector then remove the cable connecting the digitizer to the motherboard by gently pulling.
    • An adhesive pad attaches this component to the motherboard. To remove it, use a pair of tweezers to gently pry it upwards.
  8. BLU Life XL Screen Replacement: 手順 8、 3の画像 1 BLU Life XL Screen Replacement: 手順 8、 3の画像 2 BLU Life XL Screen Replacement: 手順 8、 3の画像 3
    • The motherboard should now be free from its mount in the phone, but it is still connected to the PBC data cable. To remove the cable from the motherboard, gently pry upward.
    • The motherboard is now free and can be replaced.
  9. BLU Life XL Screen Replacement, Screen: 手順 9、 3の画像 1 BLU Life XL Screen Replacement, Screen: 手順 9、 3の画像 2 BLU Life XL Screen Replacement, Screen: 手順 9、 3の画像 3
    • To remove the screen, insert the spudger between the screen and the back housing. Run the spudger along the edge of the screen and gently pry it apart.
    • If the screen starts to crack cover the screen with tape so it doesnt shatter and to protect your hands from the broken glass.
  10. BLU Life XL Screen Replacement: 手順 10、 3の画像 1 BLU Life XL Screen Replacement: 手順 10、 3の画像 2 BLU Life XL Screen Replacement: 手順 10、 3の画像 3
    • Once the screen is pried off, there should be three separate components: the screen, the milky colored digitizer, and the rear housing. Gently remove the screen and the digitizer from the rear housing.
    • This is the screen.
    • This is the digitizer.
    • This is the rear housing.
  11. BLU Life XL Screen Replacement: 手順 11、 3の画像 1 BLU Life XL Screen Replacement: 手順 11、 3の画像 2 BLU Life XL Screen Replacement: 手順 11、 3の画像 3
    • This is what the separated screen/digitizer and rear housing should look like. The first image shows the inside surfaces of both and the second image shows the outside surfaces.
    • This is the inside face of the digitizer.
    • This is the inside face of the rear housing.
    • This is the outside face of the screen.
    • This is the outside face of the rear housing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Nathaniel Ennis
メンバー登録日: 03/25/19
118 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G3, Henning Spring 2019 IUPUI, Team S2-G3, Henning Spring 2019人のメンバー
IUPUI-HENNING-S19S2G3
2 メンバー
1のガイドは作成済み
コメント 1 件
What kind of glue does it take for reassembly
Mike Reasons - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 690
