Asus MeMO Pad HD 7 Battery Replacement
はじめに
手順 1 に進むThis guide is to show you how to replace the battery in an Asus MeMO Pad HD 7. This is a simple procedure that can be accomplished by anyone.
必要な工具と部品
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
14 の人々がこのガイドを完成させました。
4 件のコメント
How did you fix the sd card port?
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
