Asus Eee PC 1215N Top Cover (Touchpad) Replacement
5分
中レベル
コミュニティメンバーによる寄稿ガイド
はじめに
手順 1 に進むRemoving the top cover is a mandatory step before to access the keyboard screw and go deeper inside the Eee PC 1215N.
Turn the power off and turn the netbook upside down.
Slide both battery catches together to release the battery.
Slide the battery out.
Remove the screws as necessary.
For top cover removing, only remove the 2 bottom screws.
The one short screw paterns to uper left screw hole directly on the PCB.
もう少しです!
終わりに
