メインコンテンツにスキップ
Apple Watch - Series 10 (46mm) Screen Replacement
必要な工具と部品
  1. Apple Watch - Series 10 (46mm) Screen Replacement, Prepare your watch for disassembly: 手順 1、 2の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Prepare your watch for disassembly: 手順 1、 2の画像 2
    • Before starting this repair, remove your watch from the charger and let its battery drain completely—the watch should shut down from low battery. A charged lithium‑ion battery may catch fire if damaged.
    • Letting the battery drain completely also prevents accidentally turning your watch back on when gripping it during repair.
  2. Apple Watch - Series 10 (46mm) Screen Replacement, Disassembly information: 手順 2、 3の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Disassembly information: 手順 2、 3の画像 2 Apple Watch - Series 10 (46mm) Screen Replacement, Disassembly information: 手順 2、 3の画像 3
    • Throughout the rest of your repair:
    • Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
    • To remove a band, firmly press in the small, oval button on the underside of the watch and slide the band out of its groove.
    • Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
  3. Apple Watch - Series 10 (46mm) Screen Replacement, Mark your opening picks: 手順 3、 3の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Mark your opening picks: 手順 3、 3の画像 2 Apple Watch - Series 10 (46mm) Screen Replacement, Mark your opening picks: 手順 3、 3の画像 3
    • If inserted too far, an opening pick can damage your watch. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. Apple Watch - Series 10 (46mm) Screen Replacement, Heat the screen: 手順 4、 1の画像 1
    • Strong adhesive secures the perimeter of the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the screen for two minutes to soften its adhesive.
    • Alternatively, you can use a hair dryer or heat gun—but be careful as extreme heat can damage the screen and/or battery.
  5. Apple Watch - Series 10 (46mm) Screen Replacement, Insert an iFlex: 手順 5、 3の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Insert an iFlex: 手順 5、 3の画像 2 Apple Watch - Series 10 (46mm) Screen Replacement, Insert an iFlex: 手順 5、 3の画像 3
    この手順で使用する道具:
    iFlex Opening Tool
    $11.99
    • The gap between the screen and frame is extremely small. You'll need a thin tool such as an iFlex to create an initial gap.
    • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Consider wearing gloves to protect your hands.
    • Insert the iFlex at a downward angle between the bottom edge of the screen and frame.
  6. Apple Watch - Series 10 (46mm) Screen Replacement, Pry up the screen: 手順 6、 2の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Pry up the screen: 手順 6、 2の画像 2
    • Prying up the screen may take multiple attempts. If you're having trouble, apply more heat and try again.
    • With one hand, push down firmly on the watch's frame to secure it in place.
    • With your free hand, hold the iFlex and push the edges up to make it more rigid.
    • The iFlex should be slightly "U" shaped.
    • Pry up the screen enough for the iFlex to lay flat on its own.
    • The iFlex doesn't need to be inserted far, as it can easily damage the screen cables near the bottom right corner of the watch.
    • Leave the iFlex inserted under the screen.
  7. Apple Watch - Series 10 (46mm) Screen Replacement, Insert an opening pick: 手順 7、 3の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Insert an opening pick: 手順 7、 3の画像 2 Apple Watch - Series 10 (46mm) Screen Replacement, Insert an opening pick: 手順 7、 3の画像 3
    • Do not insert your opening pick more than 3 mm under the screen when separating the adhesive, as you risk damaging your watches internals.
    • Keep the iFlex flat to maintain a gap between the screen and frame while inserting an opening pick.
    • Insert an opening pick between the screen and iFlex.
    • Remove the iFlex.
  8. Apple Watch - Series 10 (46mm) Screen Replacement, Separate the screen adhesive: 手順 8、 3の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Separate the screen adhesive: 手順 8、 3の画像 2 Apple Watch - Series 10 (46mm) Screen Replacement, Separate the screen adhesive: 手順 8、 3の画像 3
    • Slide the opening pick around the bottom left corner and up the left edge.
  9. Apple Watch - Series 10 (46mm) Screen Replacement: 手順 9、 2の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement: 手順 9、 2の画像 2
    • Continue sliding your pick along the top edge and around the top right corner, stopping just after the digital crown.
    • Don't slide your pick past the digital crown—you risk damage to the screen cables.
  10. Apple Watch - Series 10 (46mm) Screen Replacement, Separate the remaining adhesive: 手順 10、 2の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Separate the remaining adhesive: 手順 10、 2の画像 2
    • Insert the long edge of an opening pick between the left edge of the screen and frame.
    • Twist the pick to lift the screen and separate any remaining adhesive.
  11. Apple Watch - Series 10 (46mm) Screen Replacement, Swing open the screen: 手順 11、 3の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Swing open the screen: 手順 11、 3の画像 2 Apple Watch - Series 10 (46mm) Screen Replacement, Swing open the screen: 手順 11、 3の画像 3
    • Pull the right edge of the screen over the digital crown.
    • If the screen feels stuck, go back around it with an opening pick to separate any adhesive.
    • Swing up the left edge of the screen so it's upright. The screen should be to the right of the digital crown.
    • During reassembly:
    • This is a good point to plug in your watch and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
    • Follow this guide to apply new screen adhesive and reseal your watch.
  12. Apple Watch - Series 10 (46mm) Screen Replacement, Stand the watch up: 手順 12、 1の画像 1
    • Flip your watch so the screen is on your workspace and the frame is upright.
    • Keep the screen secured and the frame supported upright for the remaining steps.
  13. Apple Watch - Series 10 (46mm) Screen Replacement, Peel up the screen cable tape: 手順 13、 3の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Peel up the screen cable tape: 手順 13、 3の画像 2 Apple Watch - Series 10 (46mm) Screen Replacement, Peel up the screen cable tape: 手順 13、 3の画像 3
    • Use tweezers to peel up the tape covering the two screen cable ZIF connectors.
  14. Apple Watch - Series 10 (46mm) Screen Replacement, Flip up the locking flaps: 手順 14、 3の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Flip up the locking flaps: 手順 14、 3の画像 2 Apple Watch - Series 10 (46mm) Screen Replacement, Flip up the locking flaps: 手順 14、 3の画像 3
    • Use the tip of an opening pick to pry up the small, hinged locking flaps on both screen cable ZIF connectors.
  15. Apple Watch - Series 10 (46mm) Screen Replacement, Heat the screen cable: 手順 15、 1の画像 1
    • Strong adhesive secures the screen cables. Heating the cables softens the adhesive, making them easier to separate.
    • Heat an iOpener and lay it on the screen cables for two minutes to soften the adhesive.
  16. Apple Watch - Series 10 (46mm) Screen Replacement, Separate the screen cable adhesive: 手順 16、 2の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Separate the screen cable adhesive: 手順 16、 2の画像 2
    • Slide an opening pick under the screen cables to separate it from the screen.
    • If you're having trouble, apply more heat and try again. Don't use excessive force.
  17. Apple Watch - Series 10 (46mm) Screen Replacement, Disconnect the screen: 手順 17、 2の画像 1 Apple Watch - Series 10 (46mm) Screen Replacement, Disconnect the screen: 手順 17、 2の画像 2
    • Use tweezers to grip both cables and pull them out of their sockets at the same time.
  18. Apple Watch - Series 10 (46mm) Screen Replacement, Remove the screen: 手順 18、 1の画像 1
    • Remove the screen.
終わりに
ある他の人がこのガイドを完成しました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
212,746 ポイント
1,039のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,611のガイドは作成済み
1件のガイドコメント
Hallo , wo kann man den den Bildschirm Kaufen 46mm ?
Fabio - 返信
コメントを追加
統計データ:
過去 24時間: 38
過去 7 日: 191
過去 30 日: 883
今までの合計 7,043
