メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Reseal an Apple Watch
必要な工具と部品
  1. How to Reseal an Apple Watch, Clean the watch frame: 手順 1、 2の画像 1 How to Reseal an Apple Watch, Clean the watch frame: 手順 1、 2の画像 2
    この手順で使用する道具:
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • The following steps show how to apply new display adhesive with the display already installed. If you're installing a new screen or removed your screen jump to Step 6 of this guide.
    • Apply a little bit of isopropyl alcohol (>90%) to a cotton swab, or Q-tip (or use a cleaning pad) and gently remove the old adhesive on top of the watch frame.
    • To remove the adhesive on the side with the display cables, gently lay the display on the frame.
    • Avoid straining or tearing the display cables.
    FixBotに聞いてみる
  2. How to Reseal an Apple Watch, Clean the rear side of the display: 手順 2、 2の画像 1 How to Reseal an Apple Watch, Clean the rear side of the display: 手順 2、 2の画像 2
    • Flip the Apple Watch upside down so the display lays flat and lift the watch body.
    • Gently remove the old adhesive on the rear side of the display.
    FixBotに聞いてみる
  3. How to Reseal an Apple Watch, Prepare the adhesive: 手順 3、 1の画像 1
    この手順で使用する道具:
    • Use a pair of tweezers to carefully remove the replacement adhesive (including the blue protective film) from the backing paper.
    FixBotに聞いてみる
  4. How to Reseal an Apple Watch, Apply the new adhesive: 手順 4、 3の画像 1 How to Reseal an Apple Watch, Apply the new adhesive: 手順 4、 3の画像 2 How to Reseal an Apple Watch, Apply the new adhesive: 手順 4、 3の画像 3
    • Hold the replacement adhesive diagonally and thread it over the display.
    • Slightly tilt the display forward to align the adhesive with the frame.
    • Position the replacement adhesive on the watch frame, where the old adhesive was located.
    FixBotに聞いてみる
  5. How to Reseal an Apple Watch: 手順 5、 1の画像 1
    • Use the pointed end of a spudger to press the replacement adhesive into place.
    • To completely reseal your watch jump straight to step 14.
    FixBotに聞いてみる
  6. How to Reseal an Apple Watch, Clean the watch frame: 手順 6、 2の画像 1 How to Reseal an Apple Watch, Clean the watch frame: 手順 6、 2の画像 2
    この手順で使用する道具:
    $7.99
    • To remove the adhesive on the side with the display cables, gently fold the cables down.
    • Don‘t fold the cable sharply and only bend them to avoid cable damage.
    FixBotに聞いてみる
  7. How to Reseal an Apple Watch, Clean the rear side of the display: 手順 7、 2の画像 1 How to Reseal an Apple Watch, Clean the rear side of the display: 手順 7、 2の画像 2
    • If you‘re reusing your old display you need to remove the leftover adhesive from its rear side.
    FixBotに聞いてみる
  8. How to Reseal an Apple Watch, Prepare the adhesive: 手順 8、 1の画像 1
    FixBotに聞いてみる
  9. How to Reseal an Apple Watch, Apply the new adhesive: 手順 9、 2の画像 1 How to Reseal an Apple Watch, Apply the new adhesive: 手順 9、 2の画像 2
    • Hold the replacement adhesive diagonally and thread it over the display cables.
    • Slightly tilt the display cables forward to align the adhesive with the frame.
    FixBotに聞いてみる
  10. How to Reseal an Apple Watch: 手順 10、 1の画像 1
    FixBotに聞いてみる
  11. How to Reseal an Apple Watch, Reconnect the screen: 手順 11、 2の画像 1 How to Reseal an Apple Watch, Reconnect the screen: 手順 11、 2の画像 2
    • Lay your display flat on your working surface.
    • Hold the watch body in an upright position and grab the display cables with a pair of tweezers.
    • Before inserting the cables into the connectors, make sure the ZIF connector flaps are in an upright position. Otherwise, you risk damaging the cables.
    • Align the display cables parallel to the ZIF connectors and push them in.
    • No force is needed to push the cables into the connectors. If the cable doesn’t insert easily, it’s probably misaligned and needs to be gently removed and repositioned.
    FixBotに聞いてみる
  12. How to Reseal an Apple Watch, Secure the ZIF connectors: 手順 12、 3の画像 1 How to Reseal an Apple Watch, Secure the ZIF connectors: 手順 12、 3の画像 2 How to Reseal an Apple Watch, Secure the ZIF connectors: 手順 12、 3の画像 3
    • Use the pointed end of a spudger and fold down the black flaps on top of the ZIF connectors to secure the cables.
    FixBotに聞いてみる
  13. How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: 手順 13、 3の画像 1 How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: 手順 13、 3の画像 2 How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: 手順 13、 3の画像 3
    • Carefully adhere the old heat dissipation stickers to the ZIF connectors on the rear side of the display or apply new heat dissipation stickers where the old ones were located.
    FixBotに聞いてみる
  14. How to Reseal an Apple Watch, Remove the protective film: 手順 14、 3の画像 1 How to Reseal an Apple Watch, Remove the protective film: 手順 14、 3の画像 2 How to Reseal an Apple Watch, Remove the protective film: 手順 14、 3の画像 3
    • Use tweezers and a pair of scissors to lift and cut a corner of the protective film.
    • Remove the film from the display adhesive.
    FixBotに聞いてみる
  15. How to Reseal an Apple Watch, Reseal the Apple Watch: 手順 15、 2の画像 1 How to Reseal an Apple Watch, Reseal the Apple Watch: 手順 15、 2の画像 2
    • Align the screen and press it down firmly onto the adhesive.
    • To improve bonding of the adhesive, apply a heated iOpener to the display. Then apply pressure for a few hours —for example, place your Apple Watch under one or two heavy books overnight.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
    FixBotに聞いてみる
終わりに
11 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
258,312 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
25,710のガイドは作成済み
2件のガイドコメント
Applying this adhesive is a mess. It sticks to everything, except the watch itself. I ruined one. I will use glue instead. Great that I ordered two for two separate watches.
Krisztian - 返信 共有
Also the adhesive is not thick enough nor broad enough. Really disappointed. I trust my B7000 more!
Dieter - 返信 共有
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 108
過去 30 日: 577
今までの合計 23,299
