メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amazon Echo Show 10 3rd Gen Display Replacement
必要な工具と部品
    1. Amazon Echo Show 10 3rd Gen Display Replacement, Display: 手順 1、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement, Display: 手順 1、 2の画像 2
      • With the Echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
      • Remove the lid and set aside.
      FixBotに聞いてみる
      コメントを追加
    2. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 2、 1の画像 1
      • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
      FixBotに聞いてみる
      コメントを追加
    3. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 3、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement: 手順 3、 2の画像 2
      • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
      • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
      • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
      FixBotに聞いてみる
      コメントを追加
    4. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 4、 1の画像 1
      • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
      FixBotに聞いてみる
      コメントを追加
    5. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 5、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement: 手順 5、 2の画像 2
      • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
      • Place the shell aside.
      FixBotに聞いてみる
      コメントを追加
    6. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 6、 1の画像 1
      • Tilt the device so that the underside of the display and its neck are facing you.
      • You may need help holding it in this position. Alternatively, you could place the device on a soft surface so it doesn't get damaged.
      • Use a T6 Torx screwdriver to remove the two 5mm screws from the underside of the display neck.
      FixBotに聞いてみる
      コメントを追加
    7. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 7、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement: 手順 7、 2の画像 2
      • Lift the plate up to remove it from the neck of the device.
      • Set it aside for reassembly.
      FixBotに聞いてみる
      コメントを追加
    8. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 8、 1の画像 1
      • Use an opening tool to flip up the small locking flap on the ribbon cable connector located in the center of the exposed underside of the display neck.
      • Gently pull the cable out.
      FixBotに聞いてみる
      コメントを追加
    9. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 9、 1の画像 1
      • Tilt the device so it is in the upright position.
      • Use a TR10 Torx Security screwdriver to remove the four 11 mm screws from the top of the display neck.
      FixBotに聞いてみる
      コメントを追加
    10. Amazon Echo Show 10 3rd Gen Display Replacement: 手順 10、 2の画像 1 Amazon Echo Show 10 3rd Gen Display Replacement: 手順 10、 2の画像 2
      • Gently lift the display and its connecting neck off of the base.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Macy Ormand
メンバー登録日: 09/13/23
1,101 ポイント
6のガイドは作成済み
チーム
Western Carolina University, Team 1-4, Virtue Fall 2023 Western Carolina University, Team 1-4, Virtue Fall 2023人のメンバー
WCU-VIRTUE-F23S1G4
4 メンバー
12のガイドは作成済み
6件のガイドコメント
any idea where to purchase a replacement display?
Don Jackson - 返信 共有
Were you able to source a replacement display? I'm having troubles finding one. Thanks
Jeg4 - 返信 共有
where can I buy a replacement display for echo 10 3rd gen?
Tomasz K. - 返信 共有
@tomaszk64280 por la plataforma de amazon, pero no aparece el tutorial para cambiar solo la pantalla
ARIAS SEGUROS Y CIA LTDA - 返信 共有
Wenn ihr eine Quelle gefunden habt wäre eine info schön ich suche nun auch nach einem kleinen missgeschick...
Jan Pfotenhauer - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 24
過去 30 日: 95
今までの合計 2,654
