メインコンテンツにスキップ
Amazon Echo Power and Speaker Driver Board Replacement
必要な工具と部品
  1. Amazon Echo Power and Speaker Driver Board Replacement, Power and Speaker Driver Board: 手順 1、 1の画像 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Power and Speaker Driver Board Replacement: 手順 2、 3の画像 1 Amazon Echo Power and Speaker Driver Board Replacement: 手順 2、 3の画像 2 Amazon Echo Power and Speaker Driver Board Replacement: 手順 2、 3の画像 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Power and Speaker Driver Board Replacement: 手順 3、 1の画像 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Power and Speaker Driver Board Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Power and Speaker Driver Board Replacement: 手順 5、 2の画像 1 Amazon Echo Power and Speaker Driver Board Replacement: 手順 5、 2の画像 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Power and Speaker Driver Board Replacement: 手順 6、 3の画像 1 Amazon Echo Power and Speaker Driver Board Replacement: 手順 6、 3の画像 2 Amazon Echo Power and Speaker Driver Board Replacement: 手順 6、 3の画像 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
終わりに
10 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alexander Albert
メンバー登録日: 02/04/16
1,169 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 3-3, Wollert Spring 2016 USF Tampa, Team 3-3, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G3
4 メンバー
12のガイドは作成済み
22件のガイドコメント
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - 返信
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
Where do I get a replacement board ?
Sean Burch - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 135
今までの合計 28,399
