メインコンテンツにスキップ
Acer Aspire R7 RAM Replacement
Andrew Rodiek
Andrew Rodiek とその他 6 人の作成者
最終更新日: December 21, 2021
5 - 10 分
中レベル
作成中の学生
The Acer Aspire R7-571-6858 is a convertible laptop that features an Intel Core i5 3337U processor and weighs about 5.29 lbs. This guide aims to show you how to upgrade the RAM chip in the Acer Aspire R7 so you can get more memory for your device. Depending on how much memory you want to add you will need at the most 8GB of RAM specifically 8GB DDR4-2400 SODIMM.
The steps to change the RAM chip in an Acer Aspire R7 laptop is like any other laptop. Nearly all laptops are designed with an access panel in the bottom of the laptop. To open the panel, it is necessary to have a small-ended screwdriver. Make sure you are working on a clean surface to prevent any dust inside the panel. Before you start, make sure to unplug any cables connected to the laptop and power it down.
 Special Skills Needed: None.
Not sure about a part/model number or need technical support connect with Acer Support
必要な工具と部品
ツール
もっと見る
  1. Acer Aspire R7 RAM Replacement, Cover: 手順 1、 1の画像 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 RAM Replacement: 手順 2、 3の画像 1 Acer Aspire R7 RAM Replacement: 手順 2、 3の画像 2 Acer Aspire R7 RAM Replacement: 手順 2、 3の画像 3
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
  3. Acer Aspire R7 RAM Replacement: 手順 3、 1の画像 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 RAM Replacement, RAM: 手順 4、 1の画像 1
    • Push the retaining clips away from the RAM module, allowing the spring loaded hinge to pop up.
  5. Acer Aspire R7 RAM Replacement: 手順 5、 1の画像 1
    • Carefully pull the RAM module away from the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Andrew Rodiek
メンバー登録日: 01/13/15
601 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 3-4, Hickman Winter 2015 USF Tampa, Team 3-4, Hickman Winter 2015人のメンバー
USFT-HICKMAN-W15S3G4
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 32
今までの合計 1,993
