Acer Aspire E5-471-5456 Hard Drive Replacement
はじめに
手順 1 に進むThe Hard Drive is the memory center of your computer. Follow the steps bellow to correctly install a hard drive into your Acer Aspire.
必要な工具と部品
修理キット
キットには、この修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
Carefully place the closed computer on a flat surface, with it oriented screen down.
Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
Locate the hard drive at the bottom left corner of the laptop. On the silver plate securing the hard drive, remove the four M2X3 mm screws on each corner (refer to the red circles for screw locations).
2 の人々がこのガイドを完成させました。
