Where should the flat washer be placed?
where should the flat washer be placed? It fell out before I could see where it was located
flat washers normally go on screws. If the screw has a lock washer, they go on after the lock washer.
If it is just a spacer, then you need an exploded view, that you may be able to find on a parts supplier web site.
このアンサーは役に立ちましたか?
Looking at the parts diagram there are no washers used.
Did you mean the diffusion plate by any chance?
See the image below for its location
(click on image)
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 16
過去 30 日: 16
今までの合計 16
