Keyboard does not appear on the screen
The keyboard of the phone does not appear on the screen to unlock the phone
if you power it on and swipe the screen and the kbd does not appear (assuming it requires a pin), then the F/W has failed.
AI response:
When the lock screen PIN pad or keyboard fails to appear after swiping, it is usually caused by a temporary system UI freeze or a third-party keyboard application conflict.
You can resolve this issue by trying these troubleshooting steps in order:
1. Perform a Forced Restart
A soft reset forces the system UI to reload, which usually fixes the missing keypad immediately.
2. Boot into Safe Mode
If a third-party keyboard app (like Gboard or SwiftKey) or an accessibility gesture app crashed, it can block the lock screen. Safe Mode temporarily disables all third-party apps and forces the default Samsung Keyboard to load.
3. Connect a Physical USB Keyboard
If you cannot get the screen to respond, you can bypass the touch screen keyboard entirely.
4. Use Samsung SmartThings Find (Remote Unlock)
If you previously turned on "Remote Unlock" in your security settings, you can unlock the phone from a browser:
Let me know:
If you are completely locked out, you must clearing the system cache or performing a factory reset via Recovery Mode.
AI can help with that.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 11
過去 30 日: 11
今までの合計 11
