How to remove oil change report?
How to reset and turn off oil change report?
this is what AI on chrome has to say
To reset the service or maintenance light on most modern SEAT vehicles (like the Leon, Ibiza, Ateca, or Arona), you can use either the instrument cluster's physical reset button or the digital steering wheel controls/infotainment menu. [1, 2, 3, 4]
Method 1: Using the Dashboard / Trip Button (Older & Standard Digital Clusters)
Method 2: Using Steering Wheel Controls / Digital Menu (Newer Models like Leon MK4 / Ateca)
Most users on SEATCupra Forum agree that if your vehicle runs on a customized variable service schedule, a dedicated OBD diagnostic tool or VCDS cable may occasionally be required to clear deep adaptation channels. [1]
To help you get the exact steps:
If you share your exact model and year, I can give you the precise button sequence for your dashboard type.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 21
過去 30 日: 83
今までの合計 114
Hi @aymanmoham54813
What is the year and model of your Seat vehicle?
jayeff さんによる
