メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
中国の多国籍エレクトロニクス企業であるTCLが製造するテレビ。
TCL 32ES561 boot stopped
Every now and then when switching from TV to media it would slow down and reboot Android.
But the last time it didn't start again, it got to showing the four animated circles and got stuck there.
As soon as I plug it in, Android starts without the remote.
I tried plugging it in with the joystick pressed to start the recovery process, but it gave 'no command'.
So I searched and found a firmware, put it on a FAT32 stick, and the firmware installation completed, but at the end, 'error!'
They told me it's because the firmware must match the product code exactly, so I opened the lid and found the product code.
Need it for the model "08-RT41V02-MA200WA."
TCL replied, "Unfortunately, there are no official sources from which I can download the required file."
Where find it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The number 08-RT41V02-MA200WA is an internal manufacturer part number for the mainboard (often paired with chassis/board TPD.RT2841.PB771 or V8-R41KT01), not the consumer TV model.
To get the official firmware (f/w) for your TCL 32ES561, you should update wirelessly directly through the TV's menu or contact TCL regional support for a manual package.
Method 1: Over-The-Air (OTA) Update
This is the safest and easiest way to update your TV:
  1. Ensure your TV is connected to a stable Wi-Fi network.
  2. Press the Home button on your TCL remote.
  3. Go to Settings -> Device Preferences (or System) -> About.
  4. Select System update -> Network update to check for and install the latest available version.
Method 2: Official Manual USB Update
If you need a manual firmware file (e.g., an .img or .pkg file), it must be sourced directly from the manufacturer to match your specific TV’s exact serial and project code.
  1. Contact the official TCL Support with your TV's model and serial number to request the specific firmware package for the 32ES561.
  2. Format a USB drive to FAT32, copy the firmware file to the root directory, and use the "Local Update" or manual force-flash process (holding the physical power button while plugging the TV in).
(Note: TCL does not typically host downloadable .img files for older European/international smart TV models on public web portals, so official support interaction is usually required for manual flashes.)
  • Software Upgrade - TCL
  • 1) Upgrade with FOTA. Firmware-Over-The-Air ("FOTA"), is a way in which the firmware of a mobile device is updated wirelessly
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Method 1
Impossible to if TV don't boot.
Methond 2
Impossible to do if Support dont' give download link of firmware
さんによる
コメントを追加
回答を追加する
Paolo Holzl さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 34
今までの合計 157
