keyboard keys not working
Hi
Several keys of the keyboard are not working well. Some need to be clicked severall times with more pressure to work.
Can it be completely changed?
Well i will suggest you to use a external keyboard until you fix your laptop keyboard ans some time outdated driver can also cause this kind of issue as well so look for that as well.
このアンサーは役に立ちましたか?
Yes, the keyboard can be completely replaced. If only a few keys are faulty, try cleaning under them using compressed air or a soft brush first. If the issue persists, replacing the keyboard is the best long-term solution.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 10
過去 30 日: 42
今までの合計 378
