メインコンテンツにスキップ
In its first year in production, the Santa Fe was offered with one of two engine and transmission combinations. In North America, a fuel-efficient 2.4 L four-cylinder engine was standard equipment and could be mated with either a 5-speed manual or a 4-speed automatic.
My window glass doesn't work well
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
A better description of the problem you're having with your window would help, but I wouldn't necessarily replace the window motor as the first step, as there's always the possibility it's a problem with the window regulator; that's the mechanism that the window motor drives that moves the window up and down. The connecting belt or cable can wear out or break, and the tracks can get out of alignment which can bind up the window in certain parts of its travel. Those possibilities should be investigated as well, along with the possibility that it could be an issue with the window switch rather than the window motor.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Verify your window motors are getting full voltage and then verify your motor ground has good continuity, if both are good replace the motors; they're old and weak.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
maamoon alloo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 13
今までの合計 41
