メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung NP-NC10-KA02USは2008年11月15日に発売されたネットブックです。このコンピュータはLEDバックライト技術を採用しており、Wi-FiおよびBluetooth接続が可能です。
Operating system not found
For some days my laptop shows operating system not found I don't know why I searched on YouTube to fix that i even open my bios setup but i doesn't help and then after some time bios setup also not showing on screen i also replace the CMOs battery but it still not showing Could u plsss tell me what should I do...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hey there, I'm wondering if your hard drive might have gone out. Is the drive appearing in your BIOS' boot order?
さんによる 共有
コメントを追加
1 件の回答
OP not found is a hard drive issue. However, BIOS not showing might indicate a BIOS issue.
When you turn on a computer, the CPU reads a small piece of code in the BIOS chip. That tells it how to access the hard drive and read the MBR or GPT sectors.
From that info, it can find and load the OS.
Normally, a missing OS would be a HDD fault. Either corruption or a total failure.
Start by trying to do repair install of Windows. Look up how to do that.
if that doesn't work, remove the HDD and connected it to another computer using an external HDD enclosure.
If you can read it, remove all your data - if you do not have a recent backup.
Then reformat the drive and reinstall Windows.
You will have to reinstall all the programs you use also.
Then copy your data back.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dhruwansh dave さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 268
