メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy S21 5G Androidスマートフォンの修理および分解情報。モデルSM-G991Uを含む。
WI-FI constantly turning itself off
Okay so I got this phone second hand, it is the Galaxy S21 FE 5g, the wifi constantly turns itself off after about 10-15 minutes on the new ui 6 update, i’ve been through all settings involving samsungs smart connect, and factory reset multiple times. no cracks or outside damage. the bluetooth is fine so I know it’s wifi specific and happens on every network. it’s not my main phone but I would like to invest a little into fixing it, I just don’t know what i’d need to replace or if samsung is still as repairable as it used to be, i’ve had an iphone as my main for quite a while now
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Check for any battery saver settings being turned on... it might be that it's turning off the wifi to conserve power.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Did you figure it out ? Mine is doing the same
さんによる
I changed the power saving to high performance and it fixed the same issue I was having with the wifi turning off
さんによる
I'm having the same issue
さんによる
Same issue, and non of the solutions work.
さんによる
コメントを追加
Samsung has tech support for that. Not the sharpest knife in the world, but it is free and they can log onto your phone and look at it.
That is your best option.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dominick giovannelli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 41
今までの合計 1,521
