メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
DJI Mini 2は、2020年にDJIによって製造された小型ドローンです。DJI Mini 2は、4K/30fpsの動画撮影と10kmの720p/30fps映像伝送機能を備えています。
incompatible gimbal data error
powers on connects to drone, camera rotates left,right, up and down can view through camera. gimbal does not respond to wheel on controler. has incompatible gimbal data on display. will not take off. is i a board problem or a cable
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
did you solve this problem?
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
Let's do a little logical thinking here.
If the gimbal does its power on movement then the gimbal and cable to it from its controller in the AC are functional.
If you can view the camera, then the camera system and communication from the AC is functional.
The AC sees the gimbal and is getting data but does not like what it sees, so you are getting an "incompatible gimbal data" message.
Therefore, any commands to it from your Controller are ignored (or maybe the Controller isn't even sending the commands because of the error).
If that message appeared after your "minor" crash, then I would first suspect a dislodged cable in the AC.
But after that, a damaged PCB is a possibility.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I'm afraid the reader does not know about an AC being Altitude Controller, nor where to locate this in the drone...
さんによる 共有
AC is a common abbreviation for AirCraft
さんによる 共有
gps board ended up being culprit,bought new still didnt work, took board from another broken drone and all well now.
さんによる 共有
コメントを追加
You will need to replace the gimbal. The best website to buy parts from is: djioemparts.com.
You can buy a new gimbal here for $80 USD https://djioemparts.com/collections/dji-...
Best of luck, BetaTech Labs Repair AU
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
the gimbal responds to startup/power on and does up down left right chk ok and i can view through camera, does not respond to up/down knob on controler so would that be gimbal or motherboard
さんによる 共有
did it beep at startup?
さんによる 共有
コメントを追加
Hi, Have you done any repairs recently? have you crashed recently?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
very minor fall from about 8' into grass
さんによる 共有
Yeah, it looks like you messed up your gimbal
さんによる 共有
posting new answer...
さんによる 共有
finally was able to find solution, i replaced gps board and all is once again fine!
さんによる 共有
コメントを追加
回答を追加する
colderp さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 22
過去 30 日: 117
今までの合計 2,938
