メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年に発売された、ディスペンサーや製氷機などの内蔵機能を備えない伝統的なスタイルの自立型モデル、Bosch 冷蔵庫 B36CL80EN*に関する修理情報や詳細情報を確認できます。このページでは、モデル番号が B36CL80EN* と一致するモデルの情報を扱っています。
bosch refrigerator almost dead
my bosch refrigerator is 99% dead .no display light s or interior lights. no compressor working no fans working. if i press the water dispenser button i can hear the water valve opening
Update (02/22/24)
This is all I have
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
be nice to have a schematic. Generally those are hiden somplace undet or behind most fridges
さんによる
I have the schematic unfortunately it does not show the voltages in and out of the boards
さんによる
Were you able to resolve your problem? My Bosch 800 Series Refrigerator is having the same issue, but it started with the water dispenser not working. I replaced the valve and it worked for a day before the Main Display shutdown, but the water dispenser still works. I have a Control Board on order as my last hope for repairing my self.
さんによる
I was not able to get it fixed I changed all 3 major boards and still no luck
さんによる
How did you get the boards out to replace them? I'm not seeing how they come out.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi @clivechotalal
Have you tried resetting the refrigerator by disconnecting the power to the refrigerator for 5 minutes and then reconnecting it again to see if it works?
Seems like there's a problem with the control board (part # 12029338) but this is only based on that the power is connected to it and then it controls the operation of the refrigerator.
Given the cost of the examples shown in the link above, hopefully I'm wrong.
I cannot find a free download online for the service manual, but found this supplier where it can be purchased from.
Might be worth it to find out what's wrong before deciding to order any parts etc.
Regulates the cooling functions and temperature settings in your Bosch refrigerator.の画像
製品
Bosch Refrigerator Control Module - 12029338
$370.99
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
I tried resetting also changed all 3 boards on fridge and no difference
さんによる
@clivechotalal
Post an image of the schematic in your question. Perhaps we can work out what to check.
Here's how on ifixit iFixitでの質問に画像を追加する方法
さんによる
@clivechotalal
If you have a DMM (digital multimeter) check if there's 12V on pin 14 of the power control module. - see Item #4 IWS control on schematic
Be safety aware as there's lethal AC voltage on pin 3 and 11
What is the part number that is printed on the bottom left of the schematic?
I can only make out ---1179917 and not the first 3 digits although it may be ?001179917
さんによる
First 3 digits are 800 for thr refrigerator series
さんによる
Does the 14 on the inside board feed 12 volts to x10 on the control module or vice versa
さんによる
3件以上のコメントを表示
コメントを追加
Note that from the Power Input module X12 and X16 go the the water valve board #4. Since everything else comes off bd #1, that is a big clue. If you replaced all the boards, then either there is something wrong with bd #1, #2, or #3, or there is an open circuit in one of the connecting cables.
Bd #2 is likely an AC to DC module. So, X200 & X300 will probably have DC voltages on them. X100 will have AC voltage on it. That will shut down everything except the water valve if it is bad. That would be my 1st suspect. See if you can measure any DC voltages on X301 or X201. If no, find out why, cable or bd #2. If no AC input, then bd #3. Because of the proximity of X10 and X301, I would guess that X301 is supplying 12VDC thru X10 to bd #4. So I would concentrate on X201 voltages.
I don't think there will be a single point failure on bd #1 that will cause your symptoms.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
clive chotalal さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 26
今までの合計 792
