メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
XIAOMI Mi L32M6-EIテレビは、Mi TV 4A Horizon Edition(32インチ)としても知られ、2020年に発売されたHD Ready(1366 x 768)対応のAndroidスマートLEDテレビです。Android TVで動作し、ChromecastとGoogleアシスタントが内蔵されています。
My TV Does not Start
Hey Team,
My MI 4A TV is neither starting from the remote nor from the power button of the TV. The red light always keeps on burning in the TV, which used to turn off after starting the TV, but now it does not turn off.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
9 件のコメント:
Foxsky led tv 32 inch pawer on problem
さんによる
No my tv was after starting it white screen coming
さんによる
My tv does not start
さんによる
Tv not open
Read light show but tv not on
さんによる
@henockberhane are you looking for something?
さんによる
4件以上のコメントを表示
コメントを追加
3件の回答
@devsharma59131 that is a little known TV and of course schematics etc. are not available. WE would need to see your boards. Remove the back cover from your TV and take a look at all the boards. Check for obviously damaged components. Like blackened,charred or missing components. Post some good pictures of each board as well as one of the complete layout, so we can see what you see.
Since the red power LED light is on, that would mean your power board supplies the standby voltage. It could be an issue with the main board not "telling" the power board to turn on. For that you would have to measure the voltages on the connector from the power board to the main board cable.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Any TV with a remote has the internal remote control circuit powered all the time (red LED indicator on). When triggered, it closes a relay or solid state switch that is usually on the power board (red LED off). The power switch will trigger that as well as a signal from the remote. Therefore the likely cause would be the power board, but may be the remote receiver which is normally separate.
At any rate, it requires opening up the TV and making some tests. But, without service info it will amount to parts jockeying to find the right part - and it may be just a bad connection.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
No display white bar coming
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No display on TV and white vertical lines coming
さんによる
コメントを追加
回答を追加する
Dev Sharma さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 78
今までの合計 1,662
