Printer will no longer fax
My printer will no longer fax or answer. Line to printer tests good. Everything else works perfectly with the printer. When is goes to fax I get a notice that "unable to send or receive faxes".
Hi @jimwsr ,
Try running the test fax setup from the printer control panel and check what it shows. See p.220 in the manual
このアンサーは役に立ちましたか?
define "LINE IS GOOD" and how you know?
Is the scan and fax method is ON?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 9
過去 30 日: 19
今までの合計 444
2 件のコメント
I plugged the cord from the wall into an old fashioned phone.
What do you mean,"is the scan and fax method on"/
James Wildgust, Sr. さんによる
@jimwsr I read that in a google search about your problem. I have no idea what that is, and if you don't maybe that is your problem.
bill さんによる
