メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
M3D Microは、小型でコンパクトなサイズの低価格3Dプリンターです。
Help recognizing burned component
Hi M3D Micro owners!
I have recently noticed one component (I think is a transistor) is burned, and I need help knowing which one it is.
I didn't find any schematics for the board, so I have no clue.
I would really appreciate any help here. I want to replace the component and fix the printer.
Thanks!
画像
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Which board is this? Is this the logic board or the Power and Data board?
さんによる 共有
I think my Micro is the first one they released, since I bought it from Kickstarter. Therefore it only has one logic board.
I have edited my comment, adding the full board image.
Thanks Jacob!
さんによる 共有
Это стабилизатор питания на 3,3V для микроконтроллера. Если его пробило, через него мог сгореть и контроллер.
This is a 3.3 V power stabilizer for the microcontroller. If it broke through, the controller could also burn through it.
さんによる 共有
SOT-23 XC6206P332 or XC6206 or SMD(662K) 3,3 В/0.5A
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
check out this datasheet
https://www.diodes.com/assets/Datasheets...
GW9 = AP2127N-3.3TRG1 = 3.3V regulator
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
@ruggb same result for me. Got the right symbol and right marking.
さんによる 共有
Thank you! I think you have found it! I will order the component, replace it and let you know.
さんによる 共有
I found a cheap option to order it from Europe, if someone else is interested:
https://a.aliexpress.com/_uv6bsR
さんによる 共有
コメントを追加
Hi @kuruchy
For what it is worth here's a zoomed in image from Step.7 of the ifixit M3D Microのデータポートおよび電源ポートの交換 which shows the component.
Although what GW9 (I think) means I don't know. Looking at this link it may be some sort of voltage regulator?, but as to its value that is also something else, I don't know.
Then again it may just be the component manufacturer's marking and not a value marking
画像
(click on image to enlarge)
Hopefully a start
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
hi @jayeff, thanks 👍.
Taking a look at the circuit itself, and how it got burned, it makes total sense that it is a voltage regulator.
With GW9 at least I have a hint on how and what to test.
さんによる 共有
If anyone has more info to which component exactly is, would be great.
さんによる 共有
Taking a look at all the manuals you added, it could also be a voltage detector.
さんによる 共有
@kuruchy
True.
Long shot perhaps but looking at the image you provided are there any other similar sized ICs on the board having the same marking as the faulty one?
Sometimes more than one may be used in a circuit.
If there is it may give some idea as to what it might do, depending on where it is situated.
Very hard to know without a schematic. ;-(
さんによる 共有
コメントを追加
回答を追加する
Bruno Retolaza さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 39
今までの合計 800
