メインコンテンツにスキップ
Charging port doesn't work
Hello! When the device is plugged in via the micro-USB port, the device doesn't charge. Does anyone have any experience replacing the port, or know of any other ways to fix this issue? Thanks in advance.
For info, I have tried several cables, as well as connecting to the mains and to a laptop but in no case can the device be turned on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @es2k6
Here's a video that shows what to try that may help.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi. Thanks for the video. I just tried that, as well as updating the firmware with the bose updater. The device is recognised by the computer but still no way of turning the device on.
さんによる
@es2k6
Here's a video that shows how to disassemble the speaker. This should give you access to the charge port and if you have a DMM (digital multimeter) you can check if the port is OK electrically and you can also visually check for any problems on the motherboard
After that it becomes harder as Bose doesn't release any schematics.
さんによる
コメントを追加
回答を追加する
E S さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 53
今までの合計 2,327
