Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Here’s the Ifixit Google Pixel Buds 2の分解 guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
このアンサーは役に立ちましたか?
If anyone is attempting this repair, I had good results with using a pair of pliers and gently applying enough pressure to bend the plastic slightly to crack the seal with minimal damage to anything else
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 22
過去 30 日: 78
今までの合計 9,778
1件のコメント
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
brandon k さんによる
