Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
このアンサーは役に立ちましたか?
Hi,
Here’s the Ifixit Google Pixel Buds 2 Teardown guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 42
過去 30 日: 216
今までの合計 6,480
1件のコメント
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
brandon k さんによる
