メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
メモリのアップグレードおよびリアカバーの取り外し方法 モデル番号 21-h010
One red line occurs frequently
A red line flickers on the screen frequently.
画像
But it doesn’t appeare on white background
画像
(Red lines appear over the dark region. but the white lights works properly)
Can someone provide a guide to fix it in HP All-in-one 20-r141in
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
A white screen has all the colors on. A black screen has them all off.
That line segment is not turning off the red and is likely a connector issue, but could be the screen or drive circuitry. None of that is a simple fix.
さんによる
@ruggb Any possible guidence if it is a connector issue?
さんによる
You must open the computer up, find the connectors leading to the monitor and for pin type, disconnect/reconnect them, maybe a few times to clean the contacts. In the case of flex cable connectors, rubbing the contacts on the cable gently with a pencil eraser. There are also connectors behind the monitor which are much more difficult to get to.
The trick for the flex cable connectors is not to break the connector when opening. They are very delicate but they do open easily if you are doing it right. Refer to youtube videos. If cleaning connectors does not solve it, then it is either a deteriorated cable with an open trace or a bad monitor.
さんによる
コメントを追加
1 件の回答
This is probably a bad ribbon cable or the ribbon cable has come out of the holder a little. either way first step is usually to reflow the solder by just touching it with a solder pen to melt it and move to next one. check that it is plugged in flush with the locking connectors. If this doesn’t fix it you may have to replace the ribbon if posible or if not buy a new screen from aliexpress or alibaba
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vikash さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 1,132
