メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleが2020年に発表したメインストリーム向けのiPhone。10月23日に発売され、6.1インチOLEDディスプレイ、デュアル12 MPカメラシステム、5色のカラーバリエーションを特徴としています。iPhone 11の後継モデルです。
iPhone 12 battery replacement
hi, if i replace my iphone 12 battery with ifixit battery, does the battery health show up or not?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
No, if you replace the battery in an iPhone 12, battery health will stop working.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Does that mean that the % power remaining will not display in the upper right corner of the home screen on my iPhone 12, if I swap out the battery?
さんによる 共有
@lenayres1a93233 No, that's the battery's charge percentage, which is completely separate from the health percentage. You'll still be able to see the remaining power in the corner of your screen after replacing the battery.
さんによる 共有
コメントを追加
i do not know 100% but knowing how APPLE is with their proprietary parts its kind of a gamble to expect that. ESPECIALLY Considering even OEM parts from THEM! dont work how theyre supposed to. IE the truetone feature when replacing with an OEM screen.
i hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It will not show but you can just Use 3utools to check your health with a computer. Why in the heck would you change the battery such a new phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Battery health will not show, and you'll get a message showing that it can't confirm you have a genuine battery.
However, some places, (not many) will be able to spot weld the flex from your original battery to the replacement. Then reset the charge count.
Being so new, if there are problems with the battery, Apple should replace under a warranty seems most of the 12 range will still be under warranty.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have done it on XR, you can do it at home with spot welder. just buy battery cell for your iphone (without the flex and with more metal space to weld on). there are many tutorials on internet. after spot welding you have to reset the cycle count by icopy device.
My brand of the spot welder and icopy device is QianLi - you can buy it on aliexpress as well as me, its a little bit cheaper
さんによる 共有
コメントを追加
回答を追加する
Chris Rayn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 29
今までの合計 1,704
