メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年にDellから発売されたハイエンドなIvy Bridge世代の一般向けデスクトップ。筐体カラーはホワイト・ブラックの組み合わせまたはブラックを選択可能。
Odds this will run Win11?
I've had this system for a long time due to what I paid for it and how well it has held up over time with the i7-3770 CPU. I've also looked into upgrading it to something newer but I could never justify it due to how well the system has held up. Sadly I think it met the final boss with Win11: TPM required/8th gen+ CPU required.
Look I'm okay with taking the L on this XPS if need be but my issue now is if this will work I'm doing so at higher risk until I know it will work for sure, especially since this system is no longer supported by Dell. If I need to take an L on the Dell and upgrade it to 10 and stay there until 2025, so be it.
I've held onto it so long since I paid $40 for it a few years ago from someone who wanted it gone - this will be hard to beat. A lot of newer prebuilts are sardine cans with nonstandard motherboard and power supply combinations - it's a hard sell when this has held up so well. I will never get NVMe on 3rd gen but I've never been unhappy with it otherwise.
Besides the fact I'm potentially screwed on 6th gen unnecessarily, what hope do I have for Windows beyond 10 with the XPS?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
Hey Nick,
This image may help. I’m not sure I’ve heard needing an 8th CPU.
画像
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
Microsoft specifically says 8th gen-present is officially supported. It also lacks a TPM, so I need to see how dead I am here beyond Win10 unless that requirement is satisfied somehow elsehow.
さんによる 共有
@nick
just wondering if there are any "tpm" header pins, socket etc on the motherboard in your laptop?
Perhaps even if you could fit an after market TPM2.0 chip then maybe the CPU won't support TPM anyway.
さんによる 共有
@jayeff It's a desktop. Doubt Dell has pinouts for it, so I'd need to hope for a virtual TPM which may not even be present in the Ivy Bridge chips as it's ~1 generation too old.
My problem isn't the final boss being Win11 - it's how they arbitrarily killed a bunch of official support they didn't need to that's worrying me.
さんによる 共有
@nick
My mistake.;-(
Read the question and didn't look at the device icon
さんによる 共有
@jayeff These new requirements are downright frustrating at this point. The 3770 is old and nobody has updated drivers in god knows how long but the chips are still holding their own - outside of NVMe I see nothing that's wildly better then the 3770. I have a Win10 license for it so it's a matter of installing 10 and then 11. It also isn't infested with nonstandard motherboards and power supplies.
It should be my choice to risk it when I know Intel probably will tell me it's not supported (at my own risk) and Dell will tell me it was not tested and it's an at risk upgrade. Worst case I need to go back to 8 or 10.
さんによる 共有
3件以上のコメントを表示
コメントを追加
I just built an AMD Ryzen 7-5600x. Hopefully, that will run W11, but all my other computers are i7 and one i5 so those will stay on W10 until they die. But regressing to W8 is definitely not advised. That OS is worse than Vista IMHO. Neither of which I ever used.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I have the 10 license but I run 8.1 on the XPS.
さんによる 共有
why? W8 was as bad as Vista
さんによる 共有
@ruggb Less spyware but apps are begining to drop it so I'm probably going to upgrade it to 10.
さんによる 共有
コメントを追加
@jayeff I'm upgrading :-). Lost the HT but ehh on a 6C/6T CPU I don't care.
https://cpu.userbenchmark.com/Compare/In...
画像
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The easy way to install Windows 11 on unsupported CPUs - The Verge
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
In this tutorial, I show you how to Install Windows 11 on unsupported Hardware. even if your processor is not officially supported.
https://www.getwindowstips.com/how-to-in...
さんによる 共有
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 13
今までの合計 3,076
