メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG 32インチ非スマートテレビ
Is my tv dead?
Today I was watching an online class and a couple of mimutes after I left the class I heard a loud sound from my TV (model: 32LJ500U-ZB) and it suddenly stopped working. I tried switching plugs waiting 10 seconds or pressing the power button for 10 seconds but nothing seemed to work. Finally I ve now opened the back of the TV and there is no sign of damage except a black spot in the panel (picture below) Can I fix the TV somehow?
画像
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Yes, it is dead. The charcoal around that blue device indicates that device is likely burned out. The slot in the board is there to provide air space between high voltage connections. If it was not there, the circuit board itself would not provide enough insulation to prevent an arc over.
Bend that device over and look at the bottom. You will probably see a crack in it. That is they way they fail. There may or may not be other failed components. The charcoal needs to be removed as it presents a lower resistance than a clean board.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Can this be replaced and work fine or is it more worth getting a new TV at around 250 bucks?
さんによる 共有
コメントを追加
回答を追加する
Thalis Apostolatos さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 38
今までの合計 1,243
