メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ryobi製電動ドリルの修理ガイド、マニュアル、トラブルシューティングを掲載しています。Ryobi製電動ドリルを自分で修理するために必要な情報をすべて揃えました。
Where to start? Ryobi LSD120
I have a very old compact drill that has served me very well. But it’s died. I would like to fix it. I have recharged both batteries and swapped them out: nothing. It was working ok then just stopped - no sign of anything going wrong beforehand. Where do I start with identifying what’s wrong? Any suggestions as to most likely causes of the problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Used carbon brushes, corroded battery terminal or faulty trigger switch would be my first bet
さんによる
Thanks for your suggestions. I'll test the batteries then move on to these.
さんによる
コメントを追加
1 件の回答
ベストアンサー
The above answer is assuming the batteries are actually good, which is the first potential cause. They may appear charged but have such high internal resistance that you can’t get enough current out of them. Try testing them with a resistance load and a multimeter.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks, I'll test that. I think it unlikely that this would happen with two batteries simultaneously, but I'll rule it out first.
さんによる
Hi there. I also have Ryobi LSD-120 drill with two batteries. If the batteries fail to charge, it will probably mean the voltage of the batteries has dropped too low ! You could try to "jump start" them with a 12V battery charger, for a few seconds, but that would only be a temporary fix.
You can buy new batteries from Ali express in China for only $16 US. each at the moment Ken T.
さんによる
コメントを追加
回答を追加する
RoNZ さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 416
