メインコンテンツにスキップ
An HP notebook laptop in the EliteBook series released in May 2013
5回答 すべてを表示
What is the cost to repair laptop's broken hinge?
One side of the laptop just started making sound when I opened it and soon I saw that one hinge broke. I'm unable to fix it myself. I need help regarding this or if you can tell me how much will it cost to get repaired?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @skaur ,
I don’t know what the cost would be, you would need to contact a reputable, professional laptop repair service and ask them.
If you wish to try repairing it yourself then here’s the maintenance and service guide for the laptop. Go to p.119 to view the necessary pre-requisite steps and then the procedure to remove the display assembly. It is during this procedure that the hinges can be accessed.
On p.38 Item #5 you will find the part numbers for the different types of hinges available, depending on the different types of LCD panels that can be used in the laptop.
Search online using the appropriate part number only to get results for suppliers of the part.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Simran さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 12
今までの合計 408
