メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年10月13日に発表され、10月23日に発売されたAppleのフラッグシップスマートフォン。6.1インチのOLEDディスプレイ、LiDARを搭載したトリプルレンズリアカメラシステム、5G通信に対応しています。iPhone 11 Proの後継機です。
Dark spot on camera
Hello!
Today I was taking a picture at a white background and I noticed this dark shape on my camera. I thought that it was dust or something on my lens and cleaned it carefully with some cotton and some cleaning substance for lens and they looked clean with no scratch or anything. When I opened the camera app again, the spot was still there. I never dropped my phone in water or anything. I dropped it from like 40cm on its face, but it's been like a month since then and i checked my old photos. The spot wasn't present.
Definitely it's something in there. When i zoom in, the spot gets bigger. When i zoom out, it immediately disappears, no matter the zoom out value under 1. Also, in portrait mode the spot isn't visible.
What can it be? A friend of mine told me that it can be a software problem but i doubt…
Thank you!
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
same this problem how remove it
さんによる 共有
@akhilsekhar What these phones have in common is that something has gotten onto the lens of the camera inside the phone, behind the outer protective glass where you can't get to it. Some of the tricks described below involve knocking the dust or dirt away from the lens so it's not being seen; sometimes it works and sometimes it doesn't.
The only way to get to that camera lens to clean it is to open up the phone and remove the rear facing cameras. Clean them with compressed air and/or lens cleaner and reassemble.
iPhone 12 Pro リアカメラの交換
さんによる 共有
Seems to happen on all telephoto lens. Apple says even ip68, microscopic dust gets in via the receiver. If out of warranty to fix is £198….
さんによる 共有
4 years later and this still works thank you I was freaking out
さんによる 共有
コメントを追加
8件の回答
最も参考になった回答
I resolved it last year with the trick mentioned somewhere:
  1. Make your phone stand up on its own
  2. Then push it so it falls forward or backwards flat on the table (it should make a big bang on your table).
  3. The force of the gravity will make that small dust particle move, in my case it moved out of the frame
  4. If still there, repeat the step 1-3 again.
Haven't had issues since then, hope it helps guys.
このアンサーは役に立ちましたか?
スコア 43
60 件のコメント:
Didn't work for me ;(
さんによる 共有
oh my god this actyallt worked i love you
さんによる 共有
saved my life bro
さんによる 共有
Good lord it actually worked ! I had to make it fall hard for about 7 to 8 times but it worked !
さんによる 共有
OMG THIS WORKED!!! Thank you!! I spent days/hours trying to fix this.. I sat it on my dresser and lightly dropped it twice and it fixed!!!!
さんによる 共有
55件以上のコメントを表示
コメントを追加
Solved by sending it to an Apple service. Apparently, it was a problem with it and it was repaired on warranty. Common problem, especially with iph 12. Good luck!
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Do i just go to apple service and show them the problem?
Do i have to pay them?
さんによる 共有
@Muhd Norazlami If your iPhone is still on warranty, it’s gotta be free.
さんによる 共有
How long does it take for them to repair ?
さんによる 共有
I went to apple store and they said they have to replace the camera and since I don't have a warranty it would be almost $200!
さんによる 共有
I confirm that it worked perfectly in two tries with a iPhone 12.
さんによる 共有
1以上のコメントを表示
コメントを追加
Hi there,
this spot you are seeing in your photos is probably due to some damage on the camera lens camera or the glass over the camera. Have a look to see if you can see any marks on the lens. I actually noticed I have a similar problem with my iPhone 7, although like yours it is very minor. Also do try to update the software to avoid and variables. You should be able to update to IOS 14.4
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Hey Quinn,
Thank you for your answer. I took a look again at my lens, after i cleaned them and i used a lantern to check them for scratches by looking at their glare from different angles. Nothing wrong. Not even on the inside. Also, I have iOs 14.4. I simply don't understand :(
さんによる 共有
@endru Looks to be a very tiny spec of dust or a smudge on the inside of the glass. Very very small and hard to see without magnifying but definitely visible to the camera unfortunately.
Based on your description of it disappearing under 1x zoom, it's likely just on the glass covering the telephoto camera and not the wide or ultrawide cameras. You could potentially take this piece of glass off the phone to clean it or replace it?
さんによる 共有
This is dust particles that have entered into the camera’s sensor. There is no way of removing it as it is enclosed and opening the sensor will immediately destroy the camera module. This is a very common case when the lens has been broken and dust can enter or dust is getting into the device due to a broken screen etc.
さんによる 共有
If black specks appear in pictures, you will need to remove dust from the surface of the image sensor using [Clean image sensor]. Press the Menu button, select Clean image sensor in the Setup Menu, highlight Clean now, and press OK. The camera will check and clean the image sensor.
Regards,
Will
さんによる 共有
コメントを追加
I just realised I have this issue. Phone has been well protected. Only on the 1x photo, it disappears on all other setting from 1.2x. My phone is out of warranty, what can I do to fix this?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have this same exact issue. Any resolution?
さんによる 共有
コメントを追加
thanks so much! was having a $@$*!& w e then i noticed the black dot on one picture i took… tried the trick once and it fully removed it ! yay
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I really thought this was impossible to work…
3 times the manipulation and then… magic the 3 spots I had disappeared 🤩
Thank you so much
さんによる 共有
What do you mean by 3 times the manipulation
さんによる 共有
コメントを追加
Thank you so much
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The dark spot on your iPhone's camera doesn't have to be a software glitch. If your camera lens has smudges or any other kind of debris, it can also add a black spot to your photos. In this case, take a soft or microfiber cloth and gently clean your iPhone's camera lens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i thought it's impossible buti it worked😍 Thankyou so much
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
andrew さん、ありがとうございました!
統計データ:
過去 24時間: 23
過去 7 日: 160
過去 30 日: 777
今までの合計 114,439
