メインコンテンツにスキップ
Why won't my MacBook boot up.
I have a 15 inch non unibody MacBook pro that won’t turn on. It originally turned on when I got it last year no problem. Then it started to take longer and before harder to turn it on. I recently took it out of storage to turn it on and can’t get anything out of it. Last time i had to do something with the ram when it was plugged in to turn it in. Is it the pram battery?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Yes its possible your pram battery failed, also make sure your ram you put in was compatible( 667mhz ddr2 pc 5300 or 667 MHz DDR2 SDRAM). Try a pram reset or smc to see if it comes back on.
Hope it works,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Owen Hewitt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 88
