メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nissan Altimaは、日産自動車が製造するミッドサイズセダンです。1957年に始まったNissan Bluebirdシリーズの系譜を継ぐモデルといえます。
Cranking but won't start
My car started running hot. Heater wouldn'twork either. My boyfriend replaced the water pump and the 2 themostats. He drove it down the road it didn't get hot. He shut it off and went to start it back. Wouldn't start only crank. So he replaced the crank senor wasn't it. Checked the plugs. It's getting fire. The fuel pump is coming on. He also took the air mass senor out still wouldn't start. I took it to mechanic he's had it for a week. He still don't know either. But keeps telling me he'll have it fixed the next day.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
the fuel pump coming on does not put fuel in the engine. The injectors are responsible for that. You need fuel, air and spark. Assuming the air filter isn’t totally blocked which would cause it to flood, and the spark is good, then the injectors are not working. Could be a timing sensor, blocked injectors or computer.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Check your security system
さんによる
コメントを追加
have your mechanic check your heater core..
Plugged heater core.
Update (03/07/2019)
or a faulty thermost that is sticking.. or installed backwards..
has your mechanic pressure tested your cooling system? and performed a leak down test?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have u tried the main
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Heather さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,925
