メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy Tab 2 10.1は、10.1インチのAndroid搭載タブレットコンピュータであり、Samsung Galaxy Tabシリーズの第2世代に属します。
Upgrading to latest Android version manually
Hi there, I have an old Samsung Galaxy Tab 2 10.1 with Android version 4.0.4. Nothing is compatible with it anymore. How can I upgrade it to the latest Android version please? I have checked and it says no updates available
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 47
7 件のコメント
Thank you so much
さんによる 共有
Yes, you can upgrade to Android 6 Lineage 13.0, I have Samsung tab 2 10.1 with that
さんによる 共有
Thank you so much Stephen. Much appreciated. How did you upgrade please?
さんによる 共有
I have samsung tab 2 and playstore dont want to work
さんによる 共有
I too have a Samsung Galaxy S - model number SM-T800 - running Android 6.0.1
When I check the updates it says it is up to date.
I would like to download an Application - Imaging Edge Mobile from Sony, so that I can check photos and videos taken on my Sony camera HX60V - It says the software is not compatible and I require Android version 7 at least to install the software.
How can I update the Android Version on my tablet?
さんによる 共有
2件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
here you go
you need to install a custom rom
Android is modified by the manufacturer to work on their device, because every device has different hardware.
https://www.youtube.com/watch?v=7V5tZi5V...
このアンサーは役に立ちましたか?
スコア 8
4 件のコメント:
I have two Tab 2's - both at now too slow to use. Wanted to see if there was a way to update. the link above is marked Private.
さんによる 共有
This was rubbish. The video whizzed through so fast and without explanation so that it was impossible to follow.
さんによる 共有
the video has gone private
さんによる 共有
As others have said, the video is private.
さんによる 共有
コメントを追加
If you go to [http:// https://forum.xda-developers.com/t/how-t...|XDA’s website] by clicking the link it should bring you directly to the how to’s of the tab 2. there is all kinds of valuable info on this site and if utilized will hopefully give you a better understanding of your gadgets. Good luck!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you William. That link was incredibly helpful!
さんによる 共有
コメントを追加
Try googling (samsung android tab 2 update ) and it will tell you how and where to go
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jackie Barton さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 36
過去 30 日: 198
今までの合計 85,557
