メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore Elite HE3は、Kenmore社製の洗濯機です。Whirlpool Duetと同一の製品です。
What does CL mean
My washer flashes CL when I power on. Will not let me choose cycle and will not start
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
15 件のコメント
I had the same problem (CL Code) with my Kenmore HE front loading washer ( Model 796.4168). This Trouble Code is not in the Use and Care Guide provided with the machine. The first deactivate instruction doesn’t work. There is no “drain and spin” button on this machine. When I was reaching over the machine to unplug it (the alternate deactivation instruction) I bumped something on the control panel, heard a beep and the CL code was gone. What did I press to (apparently) reset the Control Lock?
さんによる 共有
I had exactly the same problem. Based on your comment, I pressed extra rinse for a few seconds and it cleared the CL. Works again!
さんによる 共有
I have exactly the same problem. I unplugged the machine for a period of 20 minutes, I pressed the ‘Chime’ button down for extended period, and still doesn’t reset the error. There isn’t any ‘Spin’ or ‘Drain’ buttons. Do you have any ideas?
さんによる 共有
I have the same error, neither of the above solutions worked. I called every company I could. No answers. Help.
さんによる 共有
I have a control lock button and held it down and the error code cleared, I think that happens mostly when you accidently lean on buttons when reaching over the panel .
BabyDoll
さんによる 共有
10件以上のコメントを表示
コメントを追加
5件の回答
ベストアンサー
From Kenmore elite washing Machine Code error CL, control locked?:
This error code most likely indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
Hold the chin button down for 5 seconds and it disappears. That’s what worked for my machine. Good luck
さんによる 共有
On my machine the chime button is the soil level button with control lock written underneath in very small letters
さんによる 共有
Worked for me
さんによる 共有
コメントを追加
I had the same problem. I tried unplugging for more than 10 minutes. Did not resolve. There is no Drain and Spin button. I pressed and held the Extra Rinse button for a number of seconds. It did clear.
このアンサーは役に立ちましたか?
スコア 6
20 件のコメント:
I tried unplugging and also holding down the extra rinse button...still CL. I called the diagnostics number, and he said it was locked, so I held down the Chime button for a few seconds and it cleared. Washed is running fine!
さんによる 共有
Thank you! It was the Chime button!
さんによる 共有
Man I love the Internet… Thank you it was the chime button :-)
さんによる 共有
Chime button worked for me too....thank you!
さんによる 共有
Pressing the Extra rinse did it for me too. Love this way to get info
さんによる 共有
15件以上のコメントを表示
コメントを追加
Just below the CHIME button in very small print it says Control Lock. Press and hold CHIME button for 3 seconds to engage and disengage this function. We have a toddler who was the first to discover this.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Thank you. I had done this before, but forgot.
さんによる 共有
Thank you! We just discovered/noticed the fine print😉
さんによる 共有
tried many times but its not working
さんによる 共有
could there be any other problem
さんによる 共有
My button for the child lock got stuck and would not disengage. I had to take the panel apart and find the corresponding internal part and pressed that. It worked, do not recommend if you have a warranty or fear of electrocution.
さんによる 共有
コメントを追加
Botton to push on mine was just below Rinse and Spin button...in very small print it says Control Lock. Pushed and held it for 5 seconds and all cleared.
画像
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have the exact same washer as the photo above but none of those options are working for me. It won’t clear.
さんによる 共有
@jennifermc66899
What is the model number of your washer?
さんによる 共有
コメントを追加
Hi @frankholstein
With the machine turned on, you need to press and hold the Rinse and Spin button for 3 seconds to disable the Control Lock option.
See p.22 of the Kenmore 31552 use and care guide.
Control Lock + padlock symbol should also be printed on the panel under the button on the machine
Here's a poor image taken from the guide that may help.
画像
(click on image)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robyn さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 47
過去 30 日: 214
今までの合計 33,073
