Kenmore elite washing Machine Code error CL, control locked?
How can I unlocked??
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Mike, this error code most likely indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
このアンサーは役に立ちましたか?
Thanks dude...
For the kenmore elite the Cl error was cleared by the stay fresh button. It also says control lock above it
On some models, the control lock is also the chime button. Press and hold that for 5 seconds, and you're good as new.
On my model, Accela-wash, press and hold the extra rinse button which also has control lock on it
Holding the chime button for 5 seconds worked for me! Thank you! :)
このアンサーは役に立ちましたか?
If you look closely under the printed word "Chime" is says in VERY SMALL letters/words "Control Lock" Wheewww - thought I was gonna have to call for expensive service :(
Thanks! Holding the control lock button for 5 seconds helped me! Saved me $80 for a service call!
It worked by holding extra rinse
Thanks Mike holding the chime button for 5 seconds worked!!!!
Worked on my Kenmore Elite!! Just press and Hold the Chime button for 5 seconds.
Y'all another brand of Kenmore it's the Extra Rinse and that is also your Control Lock/ mecv
このアンサーは役に立ちましたか?
We have model number 796 and this worked for it. None of the above---unplugging it, holding chime button, etc., worked. Thank you so much!
The same thing for me.. but on my model I pushed the control lock for about 10 seconds and it finally reset.
On my model, pressing the Chime button, which is also Control Lock (CL) worked like a charm,
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 15
過去 30 日: 119
今までの合計 45,780
5 件のコメント
Thanks you. Holding the rinse button worked.
Jeannette Trapp さんによる
I tried everything Chime button, unplugged and plugged it back but nothing works. What should I do
Nafisha Mamdani さんによる
Hi @nafishamamdani,
What is the make and model number of the washer?
jayeff さんによる
I did the same and it didn't worked for me
Socorro Ramirez さんによる
@socorroramirez
jayeff さんによる
