メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
I spilled some water over my iPhone 6 pleade help.
I accidentally spilled some water on my iphone 6 and it still works but the screen is glitch very badly i tried drying it out but still does not work. The ringer button and sound button does not work anymore please help also touchscreen not as sensitive plus a faded picture of what app I opened
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hey ShadowJax,
I recently had the same problem on my mom's iPhone 6s. She had already put the phone in rice, which I would not recommend, as that just leaves a heavy coating of minerals on the logic board. What I would do is pull open the phone, remove the logic board, and drop it in some isopropyl alcohol. This will displace the water on the logic board, preventing further corrosion. Make sure to remove the IC shields, as no water will come out underneath them. This can be done by rotating heat around the edge of the shield with a heat gun. Once you hear popping sounds, you can start to pry it up with a pliers. You will not need to remove them all (more info here). One is also a sticker that you can peel off.
Once you have done that, either purchase an ultrasonic cleaner like this, or bring it to a repair shop/friend who has one. Have them drop it in there in isopropyl alcohol for 30-ish minutes. This will not only clean off minerals plastered to the logic board, but it will also clean underneath the ICs.
After it is done cleaning, let it sit for about 5 minutes to dry. You will have to dry off some, but most of it will evaporate off. Then, place it back into the phone and hope all goes well! 9 out of 10 times the display has significant damage or is nonfunctional, so you will most likely need to replace it. From what you have said, it sounds like there is significant damage. I would recommend purchasing one from here and purchase this or this. Replace it with this guide.
If your home button is not working, DO NOT replace it. You will no longer have touch ID functionality. If it is broken, you will either need to get it professionaly repaired, or do this. Remove it with this guide.
Hope this helps,
-Tanner
iPhone 6 ロジックボードの画像
ガイド
iPhone 6のロジックボードの交換
難易度:
中レベル
30 minutes - 2 hours
iPhone 6 LCDとデジタイザの画像
ガイド
iPhone 6 LCDとデジタイザの交換
難易度:
中レベル
45 minutes - 2 hours
iPhone 6 ホームボタンの画像
ガイド
iPhone 6 ホームボタンの交換
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
ShadowJax さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 348
