メインコンテンツにスキップ
レノボの薄型軽量ビジネス・ノートパソコンThinkPad X1 Carbonの修理ガイドと分解情報。
Why is my laptop doesn't turn on?
When I press the power button the lights come on but the screen is black. I heard the ventilator is working. The keyboard has a backlight but nothing is to be seen on the display. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi,
Connect an external monitor and see if there is a display on it with the laptop turned on.
If there is no display on the external monitor either then you have either a GPU or motherboard problem.
If there is a display on the external monitor, shine a torch at an angle close to the laptop's LCD screen and see if you can detect the desktop image. If it is there it will be very faint so it might be easier to try this in a darkened room.
If there is a display detected then you have a backlight problem. This could be caused by a faulty backlight power supply on the motherboard, faulty backlight power cable (maybe combined in the video cable), faulty backlight power cable connection at either end (motherboard or screen), faulty lid sensor or faulty LCD screen.
If there is no display detected then you may have a faulty video cable, video cable connection at either end or a faulty screen.
Here is a link to the ifixit Lenovo ThinkPad X1 Carbon guide which may be of some help.
Here is a link to the service manual for the laptop which may also help
Update (12/29/2017)
Hi ,
Here is a link that may be of interest to you.
see the post on the page by "morganae" (2nd post down the page) for a solution
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
I plugged it to external monitor but nothing is showing on, so I search for the hardware solution.
さんによる
コメントを追加
回答を追加する
Alex Sander さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 28
今までの合計 22,459
