メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mavic Proは、2016年11月に発売された折りたたみ式のコンパクトなドローンで、4Kビデオ撮影に対応しています。モデル番号はM1Pで、コントローラーのモデル番号はGL200Aです。
camera has water inside
hi there,
i was flying sideways and drowned my mavic pro in a tree which fall then in a river (sweet water). Found it again 24 hours later in about 4 meters under water -
everything works fine but it got water inside the camera which is now stuck on the glass in front of the lens and obviously can not disappear by itself. I opend the little screws but did not dare to go further as the parts did not want to get loose. I also see a golden ring near the lens cover which could hold it in place...?
any help?
Thanks anyway!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Do not charge it! Follow these guides to clean all the parts to help prevent water from corroding it. Do it ASAP!
Read this: Electronics Water Damage
Disassembly: DJI Mavic Pro の分解
Proper cleaning demonstration: iPhoneの水濡れ・水没ダメージからの復旧方法
As for the camera, there is no hope. You'll need to replace it. Use the teardown to replace it and any other non-functioning part. I recommend taking it low and easy the first few flights to make sure everything's working.
Hope this helps!
iPhoneの画像
ガイド
難易度:
難しい
1 - 2 hours
DJI Mavic Proの画像
ガイド
DJI Mavic Pro の分解
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
In that case that the camera can not be opened I try to remove the glass and find something to replace it (because the camera is working fine, it is only a waterdrop behind the glass which is in the view,..), if i kill it i have to excange it anyway...
Thank you!
さんによる 共有
actually maybe just exchange open the glas, release the moisture and put on a ND filterlens would solve the problem :)
さんによる 共有
Jeronimo I do not recommend that. You should replace it. 24Hr underwater also penetrated the sensor, which you can not fix. Have you cleaned the drone using the instructions above? This is something you should have done days ago. If you haven't done it yet, then the corrosion has probably already caused irreversible damage.
さんによる 共有
コメントを追加
回答を追加する
jeronimo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 23
今までの合計 2,173
